• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Land Desktop
    SDI Mode????
    5083 Views, 4 Replies
    02-01-2007 12:19 PM
    When I try to close out of a single drawing, command line says that I cannot close while I am in SDI Mode...what does that stand for?
    Please use plain text.
    *Dennis Hyman
    Re: SDI Mode????
    02-01-2007 12:29 PM in reply to: abc2006
    SDI mode is Single Drawing Interface. 0 allows for multiple drawings, 1
    allows for only one drawing at a time. Are you trying to close out of a
    single drawing while leaving the AutoCAD window open? That's the only thing
    that I can think of that will give you that error.
    wrote in message news:5472017@discussion.autodesk.com...
    *Don Reichle
    Re: SDI Mode????
    02-04-2007 01:28 PM in reply to: abc2006
    snip>That's the only thing that I can think of that will give you that
    error.
    At 1st I thought this might be due to a 2K7 issue that's being discussed
    here.
    But a trip to the Knowledge Base helped me to find out that this particular
    issue has been around awhile. I found 4 possibilities using "land desktop
    sdi" - w/o quotes - as you'll see in my tinyurl below:
    http://tinyurl.com/yupscg
    HTH you get this thing straightened out.
    Don Reichle
    "The only thing worse than training your staff, and having them leave is -
    not training your staff, and having them stay." :-o
    A reminder taken from Graphics Solution Providers' Calendar page
    !! Please discuss whatever we tell you with your SysMgr !!
    !! They appreciate staying in the loop :-) !!
    C3D/LDT/CD-2K7 SP2A
    AMD Athlon64 2.2GHz 2GB RAM
    XPPro 32bit SP2
    WD Raptor 10K-rpm 37GB HD
    Nvidia GeForce FX 5200 128MB
    "The only Constant is Change".
    "Dennis Hyman" wrote in message
    news:5472047@discussion.autodesk.com...
    New Member
    benjineer
    Re: SDI Mode????
    09-06-2011 09:08 AM in reply to: *Don Reichle
    I was having the same problem.  None of the answers said how to make it go away, so I tried the obvious.
    To make it go away:
    Type SDI at the command prompt and Enter.  It will ask what to change it to.  Type 0 and Enter.
    I still don't know how it got activated.
    New Member
    Stovetopsue
    Re: SDI Mode????
    09-21-2011 02:21 PM in reply to: abc2006
    I had similar issue & just like benjineer, I have no idea how it got changed in the first place! I'm just glad I found this forum!
    Anyone know how it could have got changed without typing in 'SDI' so I male sure not to do it again??
