Hey gcboshers;
I've always used ALIGN to do what you're discussing, and only used 2 common
points between the Image and the dwg's Linework.
Sometimes it takes a couple of tries, but other times the 1st attempt is
successful "enough" due to the Image's "scale".
HTH
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
LDT-2K4
Intel Celeron 2.5GHz
XPPro 32bit SP2
1GB RAM
Intel 82865G 64MB
wrote in message news:5155672@discussion.autodesk.com...
Down and dirty, how do you rubber sheet a image that is attached to the
AutoCAD dwg?
It's been a couple of years, and after reading the help, which made it sound
like I was doing it right, the outcome was not desirable.
Pick first point, i pick point on image I want moved or stretched to the new
point (second point) point of intersection of the two lines that create the
corner of the lot.
I do this to all four corners even though one corner I already have lined up
and when finished none of the four corners lineup. Even if i realign the
original corner the other 3 still do not align.
Simple, just cannot get it to work.
