Not to be arguementative, but being that I'm just a lowly draftsman, I did
have this verified through two registered land surveyors here in the office.
Both stated that railroad stationing along curves was based 100' chords, and
that the actual arc length between stations would actually be longer. The
reason for this being done is because railroad curves are spiral, and are
very difficult to define in the field. It's much easier to lay out by chord
definition.
Either way, the best thing to do is to get the railroad design plans, and
verify for yourself. I've personally tried to produce a centerline curve on
a railroad, and never have had the curve stations match the description.
Only with the plans can you accurately place the centerline, with the
tangent in, tangent out, and the spiral information.
"Jon Rizzo" wrote in message
news:419e028a$1_3@newsprd01...
> I don't believe this statement is correct. Railroad alignments are
> stationed in exactly the same way that roadway alignments are stationed.
> The difference is that railroad alignments and roadway alignments define
the
> "degree of curve" differently. Roadway alignments define the degree of
> curve using the "arc" definition (the central angle subtended by a
circular
> arc of 100 feet, or Dc = 100 * Delta / L), and railroad alignments define
> the degree of curvature using the "chord" definition (the central angle
> subtended by a chord of 100 feet, or Dc = 2 arc sin (50 / R) .
> As steve said, this has nothing to do with stationing. In both cases,
> stations are measured along the path of the alignment, not along 100'
> chords. If there existed a roadway alignment and a highway alignment that
> were identical (the same tangents, spirals and RADIUS curves) the
stationing
> would be identical. The only difference would be the Dc of each curve.
> Jon Rizzo
> Langan Engineering and Environmental Services, Inc.
> "Dennis Hyman" wrote in message
> news:419d14be_3@newsprd01...
> > Railroad curves are stationed by 100' chords (called chord definition).
> So,
> > therefore, your curve length is going to be different from the
stationing.
> > You will need to get the design plans for the railroad in order to
> > accurately recreate the centerline.
> > Also note that many railroad centerlines are spiral (thus the reason for
> the
> > chord stationing).
> > "newtoneng" wrote in message
> > news:26046836.1100802141466.JavaMail.jive@jiveforum2.autodesk.com...
> > > I have stationing from a Norfolk Southern. I was told that they base
> their
> > stationing off of chords instead of using arc lengths. Is there an
option
> in
> > Land Development Desktop to station this way?
