• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Land Desktop
    Active Contributor
    Profile and Alignement Issue
    86 Views, 2 Replies
    06-24-2008 05:11 AM
    I am hoping that somebody out there can help me out with a problem i'm having with profiles. Basically, after I've created my alignment, and sampled it from the profile menu, when I got to insert the profile, I get this strange error.. I guess its not recognizing the LDD command... (if anybody has any ideas, I would greatly appreciate it) - I'm using LDD 2008. thx.
    Command:
    Alignment Name: STM-A Number: 22 Descr: 6-23-08 KAR
    Starting Station: -25.00 Ending Station: 450.18
    Select starting point:
    Delete existing profile layers [Yes/No] Yes: Y
    Deleting profile block STM-A ...done!
    Erasing entities on layer STM-A-TXT-PROF-STAT ...
    Erasing entities on layer STM-A-CT-PROF-VGRID ...
    Erasing entities on layer STM-A-CT-PROF-BASE ...
    Erasing entities on layer STM-A-CT-PROF-EGC ...
    Erasing entities on layer STM-A-CT-PROF-EGL ...
    Erasing entities on layer STM-A-CT-PROF-EGR ...
    Erasing entities on layer STM-A-CT-PROF-FGC ...
    Erasing entities on layer STM-A-CT-PROF-GRID ...
    Erasing entities on layer STM-A-TXT-PROF-GRID ...
    Erasing entities on layer STM-A-TXT-PROF-CNTR ...
    Erasing entities on layer STM-A-TXT-PROF-LT ...
    Erasing entities on layer STM-A-TXT-PROF-RT ...
    Erasing entities on layer STM-A-CT-PROF-DGL ...
    Erasing entities on layer STM-A-CT-PROF-DGR ...
    Erasing entities on layer STM-A-TXT-PROF-FGC ...
    Erasing entities on layer STM-A-CT-PROF-FGL1 ...
    Erasing entities on layer STM-A-CT-PROF-FGL2 ...
    Erasing entities on layer STM-A-CT-PROF-FGL3 ...
    Erasing entities on layer STM-A-CT-PROF-FGL4 ...
    Erasing entities on layer STM-A-CT-PROF-FGR1 ...
    Erasing entities on layer STM-A-CT-PROF-FGR2 ...
    Erasing entities on layer STM-A-CT-PROF-FGR3 ...
    Erasing entities on layer STM-A-CT-PROF-FGR4 ...
    Erasing entities on layer STM-A-CT-PROF-FGL5 ...
    Erasing entities on layer STM-A-CT-PROF-FGL6 ...
    Erasing entities on layer STM-A-CT-PROF-FGL7 ...
    Erasing entities on layer STM-A-CT-PROF-FGL8 ...
    Erasing entities on layer STM-A-CT-PROF-FGR5 ...
    Erasing entities on layer STM-A-CT-PROF-FGR6 ...
    Erasing entities on layer STM-A-CT-PROF-FGR7 ...
    Erasing entities on layer STM-A-CT-PROF-FGR8 ...
    No entities found on selected layers!
    Loading AECC Base...
    Loading AECC Land...
    Loading AECC Subentity Selection...*Invalid*
    28.797696
    Unknown command "LDD". Press F1 for help.
    28.797696
    0.000000
    Unknown command "805.00". Press F1 for help.
    *Invalid*
    Unknown command "STM-A". Press F1 for help.
    Unknown command "STM-A-TXT-PROF-STAT". Press F1 for help.
    Unknown command "STM-A-CT-PROF-VGRID". Press F1 for help.
    Unknown command "STM-A-TXT-PROF-CNTR". Press F1 for help.
    Unknown command "STM-A-TXT-PROF-FGC". Press F1 for help.
    Unknown command "STM-A-CT-PROF-EGC". Press F1 for help.
    Unknown command "STM-A-CT-PROF-EGL". Press F1 for help.
    Unknown command "STM-A-CT-PROF-EGR". Press F1 for help.
    Unknown command "STM-A-CT-PROF-FGC". Press F1 for help.
    Unknown command "STM-A-CT-PROF-GRID". Press F1 for help.
    Unknown command "STM-A-TXT-PROF-GRID". Press F1 for help.
    1
    2
    50.000000
    50.000000
    50.000000
    2.166450E+006
    1.239450E+006
    805.000000
    -25.000000
    450.184315
    Unknown command "LEFT". Press F1 for help.
    Unknown command "STM-A-TXT-PROF-LT". Press F1 for help.
    Unknown command "STM-A-TXT-PROF-RT". Press F1 for help.
    Unknown command "STM-A-CT-PROF-DGL". Press F1 for help.
    Unknown command "STM-A-CT-PROF-DGR". Press F1 for help.
    Please use plain text.
    *John Mayo
    Re: Profile and Alignement Issue
    06-24-2008 06:53 AM in reply to: Erick Garcia Salas
    I think you may have deleted profiles using the AutoCAD Erase command
    instead of using the profile menu commands.
    Turn on attdisp & see if you find little tiny blocks that define the
    profiles. If so either erase them and redraw your profiles.
    I don't know how much work you have in this dwg but it may be easier just to
    start a new dwg & draw the defined profiles.
    If this is the case, next time when you need to get rid of a profile
    definition, go to the Profile menu, Choose Create Profile and then Undefine
    Profile to get them out of the drawing.
    If this is not the case, please disregard this babble. :smileyhappy:
    John Mayo, PE
    Project Engineer
    Conklin Associates
    Ramsey, NJ
    Civil 3D 2008 SP2, LDT 2008 SP2, Raster Design 2008
    P-IV at 3.5 GHz
    2 GB Ram
    Nvidea Quadro FX w/ 128 MB Ram
    wrote in message
    news:5964743@discussion.autodesk.com...
    thx.
    Command:
    28.797696
    28.797696
    0.000000
    *Invalid*
    1
    2
    50.000000
    50.000000
    50.000000
    2.166450E+006
    1.239450E+006
    805.000000
    -25.000000
    450.184315
    Active Contributor
    06-24-2008 06:57 AM in reply to: Erick Garcia Salas
    Thanks for the help John, however, the problem is that I can't even draw the profiles to begin with. The erase that you see on the command line that i pasted, is what the program does before inserting the new or updated profile. I'm not really sure what its doing, but I will try to recreate the project folder. thanks.
