AutoCAD Land Desktop
Active Member
wllms59!
Message 1 of 9 (1,806 Views)
Point in Drawing become selected
1806 Views, 8 Replies
04-25-2011 12:08 PM
I have searched and searched and cannot find anything regarding my problem, so here's my question:
I'm working in model space and I have all my points turned on in the drawing.  When I select a line or anything, and place it on a different layer, all the points in the drawing become selected at the end of the command.  I have to hit regen to un-select them.  Could anyone please tell me what is causing this.  I'm afraid they are going to be placed on another layer as well.
Thank you!
Active Contributor
bcollins
Message 2 of 9 (1,794 Views)
Re: Point in Drawing become selected
04-26-2011 09:22 AM in reply to: wllms59!
I'm not sure what is causing the problem or how to fix it, but my normal list of fixes when something screwy like that happens is to restart my computer, then audit and purge the drawing.  If that doesn't help then I'll try to recover it.  Sometimes it works and sometimes it doesn't.  I would also try to remove the points from the drawing and then insert them again (possibly on a different layer).
Is it just one drawing that you're having the problem with or is it every drawing on your machine?  What if you open the problem drawing on a different machine?
At any rate, I would think that if you locked the layer that the points are on then you wouldn't have to worry about them being moved to another layer.
Sorry I couldn't offer any specific advice that is going to be a sure-fire fix.
Active Member
wllms59!
Message 3 of 9 (1,788 Views)
04-26-2011 09:40 AM in reply to: bcollins
Thank you for your quick response.
I will try locking the layers or even removing them from the drawing as you, and just re-importing them as needed.  I believe that it has only done this in this one drawing.
Thanks again!
New Member
bobhakes
Message 4 of 9 (1,627 Views)
02-11-2013 10:31 AM in reply to: wllms59!
I don't see where this was SOLVED.  I'm having the same problem... with ALL my drawings, and it's not just when I change a LAYER, it happens if you change any property... I FROZE and LOCKED the Points layer but it still selects the points, ie they show up as selected in the Properties Toolbar!!!  please help
Active Member
wllms59!
Message 5 of 9 (1,624 Views)
02-11-2013 10:37 AM in reply to: wllms59!
It still happens to me too in all of my drawings.  I just try to keep an eye on the points and hit regen a lot.  It's all I know to do at this point.  Glad someone else is having this same problem.  Was beginning to think I was nuts!   :smileyhappy:
New Member
bobhakes
Message 6 of 9 (1,618 Views)
02-11-2013 11:34 AM in reply to: wllms59!
 I found this... it seems to be working... keeping my fingers crossed! :smileyhappy:
Re: PREVIOUS is selecting aeec_points
I did post the answer to this, probably under another thread. From memory, I think you need to uncheck the "Always Regenerate point
display after zoom" box in the Preferences tab in the Point Settings Dialog.
in other words:
go to the Points pull-down menu
open the Points Settings dialog box
go to the Preferences tab
uncheck "Always Regenerate point display after zoom"
it hasn't done it since!
Active Member
wllms59!
Message 7 of 9 (1,615 Views)
02-11-2013 11:46 AM in reply to: wllms59!
That seems to be working for me too!  Thank you so much for finding this!!!   :smileyhappy:   :smileyhappy:
New Member
ldiiwahabi
Message 8 of 9 (1,524 Views)
02-27-2013 01:46 PM in reply to: wllms59!
Active Member
wllms59!
Message 9 of 9 (1,519 Views)
02-27-2013 02:35 PM in reply to: wllms59!
What was written 2 posts up has solved this problem for me.  Give this a try.....
You are not logged in.
Ask the Community
