If you have the Civil module check out the Grading/Modify Point Elevations.
There are routines located there that allow you to generate a report that
displays both elevation and elevation differences using points and terrain
surface strata.
sc
wrote in message news:5083021@discussion.autodesk.com...
Is there a way to generate cut sheets based on the elevations of points in
the point database and a surface?
