• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Land Desktop
    New Member
    tinamoral34
    Pipe inside buildings
    35 Views, 1 Replies
    02-02-2012 01:41 AM
    I am going to lay out pipes inside of buildings. The pipes are all drawn in 3D with other AutoCAD software. I need to be able to create points at each bend and at different items such as valves, hangers, connections, joints etc. Some of the pipe runs will be vertical. Is there a method of doing this using LDDT?
    Valued Mentor
    Re: Pipe inside buildings
    02-05-2012 07:47 AM in reply to: tinamoral34
    You can manually place points at any time in LDD/LDC.  Just remember that a surface has a hard time with points that are directly above each oter or totally verticle planes.  It's a common practice to slightly offset a top point by a hundreth or so to get a "verticle" plane.  Also, points are relient on what user UCS you are in, and "should" (usually) only be placed when in the World UCS.
    Have you gone through the tutorials for points yet?  That will help you with all the different point placement tools.
    Reid
    Homebuilt box: I5-2500k, MSI P67A-GD65, 12gig DDR3 1600 ram, ASUS ENGTX460 Video card, WD Velociraptor WD4500HLHX HD, Win 7 64 pro.
