I would suggest that you check another Project's Pipe Run 1st dmanning, so
that you'll "know" if this malady is more widespread than you initially
supposed?
Or have you already determined that, as of now?
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT-2K4
AMD Athlon64 2.2GHz 2GB RAM
XPPro 32bit SP2
WD Raptor 10K-rpm 37GB HD
Nvidia GeForce FX 5200 128MB
"The only Constant is Change".
wrote in message news:5567136@discussion.autodesk.com...
I have a file related problem with pipes as there is only one of our
drawings that will not edit a pipe run graphically. We can edit it by data
but that is archaic and slow.
When I choose to edit any run in this file graphically it asks for which run
and when it is chosen the flow direction and node glyphs appear and the
command immediately exits without errors.
We are using LDD 2007 SP2A. The same thing happens on any machine but only
in this file.
Any clues?
