• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Land Desktop
    Member
    Parcel Manager Output options - desire station-offset vs. N/E
    414 Views, 3 Replies
    01-04-2011 07:38 AM
    We may be forced by upcoming changes in local government procedure to show Station & Offset for each vertex in our parcel descriptions (ROW, Easements, etc), rather than the Northing-Easting which it outputs now.
    Does anyone know:
    1) Is there a way to accomplish this inside any existing Land Desktop or Express Tools Routine?
    2) Does anyone know of a LISP routine that could report the station-offset of each vertex, along with the bearing and distance, curve data, etc. between the vertices?
    The ideal routine would have output similar to the current Parcel Manager:
       North: 1495637.7404        East : 2333287.9611
    Line  Course: N 05-21-30 W  Length: 165.56
            North: 1495802.5793          East : 2333272.5003
    Curve  Length: 125.53               Radius: 422.54
            Delta: -17-01-18           Tangent: 63.23
            Chord: 125.07               Course: S 81-28-23 E
        Course In: N 17-02-16 E     Course Out: S 00-00-58 W
        RP  North: 1496206.5705          East : 2333396.3044
        End North: 1495784.0349          East : 2333396.1864
    Line  Course: S 00-59-42 E  Length: 148.38
            North: 1495635.6799          East : 2333398.7631
    Line  Course: N 88-56-05 W  Length: 110.82
       Perimeter: 550.29   Area: 17,879 sq.ft. 0.41 acres
    .....except that the vertices would be labeled as Station-Offset (from current alignment, or better yet, user selected for each parcel) instead of the default North-East output.  Thanks in advance to anyone who can help out.  Happy New Year as well, Michael
    Please use plain text.
    Member
    Re: Parcel Manager Output options - desire station-offset vs. N/E
    01-04-2011 07:42 AM in reply to: 487mm
    BTW - I believe we are using Land Desktop Companion 2008.... Thanks!
    Valued Mentor
    TerryDotson
    01-04-2011 10:50 AM in reply to: 487mm
    Does anyone know of a LISP routine that could report the station-offset of each vertex, along with the bearing and distance, curve data, etc. between the vertices.
    DotSoft's MapWorks Design module contains a configurable Parcel Report that includes StationOffset fields.  Works inside LDT 2007-2009 reading information directly from the LDT parcels & alignments.  If multiple alignments exist you can choose which alignment to reference.
    Here is a dialog example.
    Member
    01-19-2011 10:36 AM in reply to: 487mm
    Thanks for the reply - we'll look into this.
