Hey Lguijarro;
So maybe you Rename the View (Junk#) instead of Deleting it until a fix is
found?
The following old joke has direct application to this (and many other)
situations:
Patient: Doctor, it hurts when I do this.
Doctor: Stop doing that.
Don Reichle
Hacker Engineering, Inc.
"King of Work-Arounds"
LDT & CD 2004
C3D 2004 SP1
On HP Pavilion a367c
2.80 Ghz/512MB RAM
XP PRO - SP2
"Lguijarro" wrote in message
news:20118318.1100701697315.JavaMail.jive@jiveforum1.autodesk.com...
Autodesk Land Desk Top 2005, Civil 2005, Survey 2005, Raster 2005
when I am In paper sapce, I make a view, called plotps, for plottIng, open
plot dialogue box, select paper size, ctb, ect., In the plot area (what to
plot) open flyout and select VIEW, box appears to the right, open flyout,
and I can select what view I want to plot, okay, done deal, now in autocad,
if I go to the view pull down menu, select named views, I am able to see all
the views I have, If I delete the view I created called plotps and I create
a new view called whatever and I go to plot, I no longer have the option to
select VIEW In the plot area (what to plot), the only options I have are
Extent, Display, Window, no matter how many view I create to plot, I do not
have the view option, matter of fact, everything is gone, plot offset,
scales ect., only the ctb files and paper sizes are there, the only way I
can get the view option and everything else, is to close the drawing and
reopen, what gives.... does this happen to anyone else??
