60 bucks, 90$, 35$.... sometimes ya jus need a bigga hamma
Joe
"Don Reichle" wrote in message
news:4830616@discussion.autodesk.com...
Hey Joe;
Thanks for the reminder re. that old gem. I've not seen that one mentioned
in a while.
Don Reichle
"King Of Work-Arounds"
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
LDT3/CD3
IntelP4-2.4
1GB RAM
Intel 64MB
"Joe Bouza" wrote in message
news:4830054@discussion.autodesk.com...
Hey guys, this is a little trick I have been using:
1. I add vertices to my pline to pick up TIN elevations at a desired
interval
2. Then define the pline as a Temp pipe run with settings set invert dist
below rim=0 )
3. import conceptual run to profile ( which is the ground profile)
4. set profile offset layer current explode pipe run to that layer
5. then define offset profile.
6. Then I trash the pipe run to avoid inadvertent confusion later
Its not as slick as some of the VBA routines out there BUT it in the box.
news:4828310@discussion.autodesk.com...
Hey S;
If you're on Subscription, you could acquire Road Output Extension (LDT3 and
later versions) and get what you want out of there.
http://tinyurl.com/87ge3
The only thing you would need to do is add a Point Code for the Offset line.
If it were along a Transition Alignment, it would just follow that wherever
you indicated.
HTH
Don Reichle
LDT3/CD3
IntelP4-2.4
1GB RAM
Intel 64MB
wrote in message news:4827793@discussion.autodesk.com...
How do I get an offset profile from the cross sections?
I can sample the terrain model at certain offsets. I can sample the
centerline from the cross sections. But I can't seem to find how to sample
the cross sections at a particular offset.
