For the VCEDIT problem, see:
http://tinyurl.com/2zsp8
I will bet the command invoke setting will also cure your unknown
PROPERTIES.
sc
"marthab" wrote in message
news:2953085.1081350169470.JavaMail.jive@jiveforum2.autodesk.com...
> I' running LD3 and if I want to edit a a profile I get the following:
Unknown command "VCEDIT". Press F1 for help.
> Also if I select something and want to list the properties I get the
following :
> _properties Unknown command "PROPERTIES". Press F1 for help.
> Any idea what the problem is?? I need help.
> Thank you
