AutoCAD Land Desktop (Read Only)
Not responding to commands
3 REPLIES 3
753 Views, 3 Replies
I' running LD3 and if I want to edit a a profile I get the following: Unknown command "VCEDIT". Press F1 for help.
Also if I select something and want to list the properties I get the following :
_properties Unknown command "PROPERTIES". Press F1 for help.
Any idea what the problem is?? I need help.
Thank you
3 REPLIES 3
Hi, For the VCEDIT problem, see: http://tinyurl.com/2zsp8 I will bet the command invoke setting will also cure your unknown PROPERTIES. sc "marthab" wrote in message news:2953085.1081350169470.JavaMail.jive@jiveforum2.autodesk.com... > I' running LD3 and if I want to edit a a profile I get the following: Unknown command "VCEDIT". Press F1 for help. > Also if I select something and want to list the properties I get the following : > _properties Unknown command "PROPERTIES". Press F1 for help. > > Any idea what the problem is?? I need help. > > Thank you
Steve, thanks a lot. It worked
Martha
syria89
do u still rememebr how u fixed you problem cause the page on the site doesnt exsite any more
for the vcedit
