AutoCAD Land Desktop (Read Only)
North Arrow and North Rotation lisp
5 REPLIES 5
2286 Views, 5 Replies
My company uses a custom north arrow. I have been trying to write a lisp to insert a north arrow with the correct north rotation. I can't use LDD because of the attributes. I am kind of new to lisp routines. Any help would be appreciated
5 REPLIES 5
As you have little knowledge of Lisp you will find it far easier to write a
program of this nature with VBA than Lisp.
However, LDD has tools to correctly insert a North Arrow allowing for North
Rotation and you would get the most return for your time simply by setting
your North Arrow up in the same way.
Laurie Comerford
CADApps
www.cadapps.com.au
www.civil3Dtools.com
wrote in message news:5611735@discussion.autodesk.com...
be appreciated
I wrote this lisp to align my north arrow based on viewport dview. It might be a good start.
(defun c:rn()
(setq tw(entget(car(entsel"\nSelect a Viewport:"))))
(setq new (cdr (assoc 0 tw)))
(cond
((= new "VIEWPORT")(setq rt(cdr(assoc 51 tw))))
((= new "LWPOLYLINE")(setq temp (entget(cdr (assoc 330 tw))))(setq rt(cdr(assoc 51 temp))))
(setq en(car(entsel"\nSelect North Arrow (must be inserted vertically:)")))
(setq elist(entget en))
(setq elist(subst (cons 50 rt)(assoc 50 elist) elist))
(entmod elist)
(princ)
thanks for the help
Or you can do some thing has simple as going into your view port and setting it tho world. Then insert your north arrow. Now if you view is twisted. and you unlock you view change your ucs to word it will also show yout tru north. Hope that help. Why use 100% when you can get by with 50%.......................LOL
Everytime I try to input the code into the command line it does not seem to do anything. Could I possibly be doing something wrong. I thank you in advance for your help.
