• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Land Desktop
    New Member
    clipaclast
    No Vertical Exists
    33 Views, 0 Replies
    02-04-2012 01:28 AM
    benefited from some earlier archives on this issue.
    Problem:
    I was no longer able to create a profile because after I sampled from surface in Profiles, I'd try to Create a Full Profile only to be told that no sampled data was found.
    A great workaround (almost all the way in my case) I found from back in 2007 by Joe Bouza was to sample from surface in Cross sections then sample the profile from Sections. This worked fine, I spent another hour superimposing DT profiles and designing my FG profile. Once I went to Edit Design Control I found out that no vertical exists. Grrr.
    Any help would be much appreciated.
