• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Land Desktop
    *Beverly
    New Project Suggestions Desired
    67 Views, 12 Replies
    10-20-2003 10:16 PM
    Description:
    I have a large Aerial Photo of a Subdivision. I have 150 close up photos
    taken on the Site. I want to create a Photo Key Plan of the Aerial Photo
    with a symbol/link for each Site Photo taken. I want to be able to click on
    the symbol/link on the aerial photo and immediately (in another window,
    which will cover approx. 1/4 of the display area) display the site photo.
    After I view the site photo and hit esc or some other key, I want the
    ability to resume the previous view of the aerial photo.
    Any ideas of how I can achieve this? What software can simplify this
    process?
    I realize this is beyond the scope of LDT but hopefully I can get pointed in
    the right direction.
    Beverly S. Carriere
    BevLynn Designs
    Please use plain text.
    Valued Contributor
    Re: New Project Suggestions Desired
    10-20-2003 10:34 PM in reply to: *Beverly
    You can add a Hyperlink to any object in Acad, then select the object, right click and select Hyperlink > Open "FILENAME" from the pop up menu...
    *bouza, Joe
    10-20-2003 10:46 PM in reply to: *Beverly
    Would'nt a windows OLE do that when you X the image view
    Joe
    "Beverly" wrote in message
    news:AA4348563039951C13AA0561817280DC@in.WebX.maYIadrTaRb...
    > Description:
    on
    > process?
    in
    > Beverly S. Carriere
    > BevLynn Designs
    *Beverly
    Re:
    10-20-2003 11:25 PM in reply to: *Beverly
    Thanks for the suggestion.
    I tried jacoppinger's idea of adding
    Hyperlinks. That works, Kind-Of. I only want to view the photo, not the entire
    IE explorer window.
    I also need to have this work outside of
    LDT, from a CD. I have to supply the client with a CD that they can
    browse.
    I am about to try OLE.
    Beverly S. Carriere
    BevLynn Designs
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    You
    menu...
    *Beverly
    Re:
    10-20-2003 11:26 PM in reply to: *Beverly
    Joe, what do you mean by X the image view? Clip?
    Beverly S. Carriere
    BevLynn Designs
    "Joe bouza" wrote in message
    news:F468461287C85660C28909CF76896F1C@in.WebX.maYIadrTaRb...
    > Joe
    *bouza, Joe
    Re:
    10-21-2003 12:38 AM in reply to: *Beverly
    Hi Beverly, When you click on the OLE the application for viewing the image
    will start. X as in top right corner of the window to close it ( you can
    govern the position and size of the application window) . But, as I read in
    your response to jacoppinger, you do'nt want the window, so, that may take
    some custom programing - I think.
    news:0261B2FAECCAC58956815B91A2AE2F85@in.WebX.maYIadrTaRb...
    > Beverly S. Carriere
    > BevLynn Designs
    > > Joe
    *Beverly
    Re:
    10-21-2003 02:14 AM in reply to: *Beverly
    Hi Joe,
    I think you may be right about the custom programming. I need to come up
    with something pretty soon though. I'm no programmer.
    Beverly S. Carriere
    BevLynn Designs
    news:E713FF09F1D724213F9A835CF8CB0451@in.WebX.maYIadrTaRb...
    in
    *Reed, Tim
    Re:
    10-21-2003 02:19 AM in reply to: *Beverly
    I think you can make this work using LDD.
    The thing about wanting to put this on a CD though makes me think you need to
    look into relative links for your hyperlinks.
    If you keep your drawing file and your snapshots files in the same folder
    structure, or snapshots in a subfolder, then you can use the
    "../photos/imagename_1.jpg" as a path for the hyperlink. That way the relative
    structure of the hyperlinks will work regardless of being on the CD or on your
    own local C drive.
    I did something similar to this for a webpage and used Map to produce the
    webpage using the "publish to web" command. If I remember right, the hyperlinks
    came through just fine to the webpage. You may want to look into that as well
    as maybe all your clients don't have ACAD.
    > > Beverly S. Carriere
    > > BevLynn Designs
    > > > Joe
    *Beverly
    Re:
    10-21-2003 02:58 AM in reply to: *Beverly
    Hi Tim,
    You must be reading my mind!
    I have the drawing file and the snapshots located in the same directory. It
    would be really nice if Express Viewer supported hyperlinks.
    My dilemma is that the aerial photograph us quire large and I was wondering
    if the image would lose its quality when zoomed in close enough to read the
    photo locations. I will try it and see.
    Also, when you did something similar, were you able to control the size of
    the hyperlink view? Is it possible to view the snapshots without viewing the
    IE Explorer Interface?
    Beverly S. Carriere
    BevLynn Designs
    "Tim Reed" wrote in message
    news:3F956A90.86C5B028@dot.state.ak.us...
    to
    relative
    your
    > own local C drive.
    hyperlinks
    well
    *Reed, Tim
    Re:
    10-21-2003 04:01 AM in reply to: *Beverly
    Beverly,
    It's been a while since I played with this stuff, but if you go the webpage
    route I think you can control the compression/file size of the images that are
    written out to web file.
    As far as controlling the size of the view you'd need to consult a web expert.
    I would imagine there is code available that could modify what ACAD writes out
    as far as size of new IE windows opened. I don't know if you can control the
    interface or what is used to view the hyperlink though. By default it will open
    the jpg in an IE window, but you may be able to hard code it to open in a
    particular image viewer at a specific size. Don't know, that's a long ways
    beyond me...
    Beverly wrote:
    > Hi Tim,
    > Beverly S. Carriere
    > BevLynn Designs
    > to
    > relative
    > your
    > > own local C drive.
    > hyperlinks
    > well
