AutoCAD Land Desktop
Member
Message 1 of 6 (180 Views)
N90°00'00"E 0.0000' Dynamic Label
180 Views, 5 Replies
11-12-2008 08:34 AM
I'm currently running AutoCad Civil 3D Land Desktop Companion 2008 SP2. Sometimes when I label a line with a direction & distance (dynamic label) the label reads "N90°00'00"E 0.0000' " when it obviously is not. I can rotate, move, stretch, etc... the line and it continues to label it the same. A couple of minutes later I'll do the same thing & now it labels the line correctly. Has anyone run into this inconsistency before? Any fixes/patches?
Distinguished Contributor
Message 2 of 6 (180 Views)
Re: N90°00'00"E 0.0000' Dynamic Label
11-12-2008 11:50 AM in reply to: ssigala
yea, I've ran into the same problem but I'm running Land Desktop 2007 with the Civil Companion and Raster Design, fully updated. I've been running into that issue for a few years now and I'm not sure about a fix other than try it again later.
AllenJessup
Message 3 of 6 (180 Views)
11-14-2008 12:24 PM in reply to: ssigala
A work around for this problem is to select the label command from the dropdown menu rather than the right click menu. You won't ever see it fixed.
Allen
Member
Message 4 of 6 (180 Views)
12-12-2008 06:59 AM in reply to: ssigala
I've noticed that I have this same problem if I try to label lines immediately after I do a save. To "reset" things I go to Points--> Point Settings, then click OK in that dialog box. (other dropdowns may have similar results) After I do that the right-click line label routine seems to work. Once all my lines have been labeled correctly I disassociate them so they won't change. Labels--> Disassociate Labels... "All". Others may disagree with doing this but I've been burned by the Dynamic labels before and I don't trust them.
AutoCAD Map 3D 2012
AllenJessup
Message 5 of 6 (180 Views)
12-12-2008 07:19 AM in reply to: ssigala
Glad to hear of another workaround. I just label with disassociated labels so I don't need to go through the disassociation process
Allen
*DougK
Message 6 of 6 (180 Views)
12-15-2008 06:06 AM in reply to: ssigala
i am an other that agrees.
burned once, years ago, and have only used static
since.
DougK - An Equal Opportunity
Annoyer
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">Others
You are not logged in.
Ask the Community
