AutoCAD Land Desktop (Read Only)
Maypo
1614 Views, 4 Replies
MTEXT alignment
Does anyone know how I can align existing text columns in an existing MTEXT box? I inherited a drawing with a list of items intended to be aligned by column and row but they are not.
Thanks!
4 REPLIES 4
in reply to: Maypo
Hey Maypo;
Whenever I'm faced with this task you've described, I always separate the
Columns - usually in Excel, because that's a Default Setup I can make use of
there. If the data needs a Total arrived at, then I'm one step ahead of that
game, by utilizing Excel.
I then Copy the necessary Range of Cells;
Open Notepad;
Paste the data there;
Select All;
Cut;
Go to AutoCAD - where I usually have the Mtext open, and waiting to receive
the text from Notepad;
Paste the data from Notepad.
It takes longer to explain, than to perform.
If you've got existing Mtext already, then just take it into Excel by way of
Notepad - to generate those columns you need.
HTH
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
C3D/LDT/CD/SVY-2K6
Intel P4-3.00GHz
XPPro 32bit SP2
1GB RAM
Nvidia GeForce2 Ti 64MB
wrote in message news:5106960@discussion.autodesk.com...
Thanks!
Maypo
in reply to: Maypo
Thanks for the info.
I just inserted the Excel spreadsheet as an OLE due to time
in reply to: Maypo
You're perfectly "safe", until the Spreadsheet grows in either width or
length (or both!) - past the "point of no return". 🙂
Don Reichle
C3D/LDT/CD/SVY-2K6
Intel P4-3.00GHz
XPPro 32bit SP2
1GB RAM
wrote in message news:5108210@discussion.autodesk.com...
davluc
in reply to: Maypo
I'm pretty new to CAD, as  most of my work is in SolidWorks. I'm making drawings for an Engineer who wants everything in AutoCad LT 2004, which I have. Is there a way to insert a excell spreadsheet into a MTEXT box. I'm using Window 7.
Dave
