PLEASE confirm prior to installing this service pack which product is installed on your computer.
Land Desktop 2007 SP2: http://usa.autodesk.com/getdoc/id=DL8234794
Land Desktop Companion 2007 SP2: http://usa.autodesk.com/getdoc/id=DL8234796
1. Verify with the original installation media.
2. Confirm with your serial number. (Your serial number for Land Desktop Companion will be the same as your Civil 3D serial number)
Please also note if you have a locked or unlocked version of our software. To determine if you have a Locked or Unlocked version of the software, go to the Help menu in Civil 3D 2007 and select About Autodesk Civil 3D. Select the Product Information button in the About window. In the Product Information window, the License Type should will read either Stand Alone - Locked or Stand Alone – Unlocked. After determining which version of the software you have, please download the appropriate patch.
