AutoCAD Land Desktop (Read Only)
Land Desktop - Alignments
2 REPLIES 2
2051 Views, 2 Replies
I have what I hope is a simple question; is there a way to generate a report in Land Desktop that would contain the coordinates of points as well the station and offsets from an alignment
2 REPLIES 2
Spoiler
I know you can do a Display Points from the Alignment pulldown to get your station and offsets, Cut and paste if necessary to a text file from your text screen.  Then I would create a group of such points and then print that for coordinate values.  As a whole like what you are asking I have not seen that option so I make do with the limitations of the software.  HTH.
TerryDotson
If you were to consider third party software, the MapWorks Points module will produce this report.  Works inside Land Desktop 2007-2009 and works directly with AECC Points & Alignments.
