AutoCAD Land Desktop
Member
RoadGuyJ
Message 1 of 5 (648 Views)
Land Desktop 2009 - Vertical Transitions
648 Views, 4 Replies
10-15-2013 10:44 AM
Can anyone tell me an easy way to vertically transition the edge of pavement on a road cross section template to follow the existing ground elevation at that offset?
What I am trying to do is run a resurfacing template and match existing cross fall. I want my new edge of pavement to not only follow a horizontal alignment but a vertical one as well.
It's been years since I used this software (2007), I'm just getting my head back into it.
Jeff_M
Message 2 of 5 (639 Views)
Re: Land Desktop 2009 - Vertical Transitions
10-16-2013 07:20 AM in reply to: RoadGuyJ
I haven't used LDT in about 5 years, longer for any section work, so this is all from dusty memories. IIRC, the template must be setup with VerticalTransition regions, then you can assign a profile to that region.
Member
RoadGuyJ
Message 3 of 5 (634 Views)
10-16-2013 07:26 AM in reply to: Jeff_M
Thanks Jeff, the template is setup right. I want to sample the edge of pavements with reference to the control centerline.
When creating separate profiles for the left and right edge of pavements there are slight discrepancies as these profiles are not sampled in referece to the CL.
Any other solutions?
Jeff_M
Message 4 of 5 (629 Views)
10-16-2013 07:40 AM in reply to: RoadGuyJ
Sorry, that's all I've got at this time.
Member
RoadGuyJ
Message 5 of 5 (623 Views)
10-16-2013 09:07 AM in reply to: Jeff_M
Cheers,
The command is Superimpose Profiles. I see from other posts that there appears to be a bug with the command.
You are not logged in.
Ask the Community
