AutoCAD Land Desktop (Read Only)
Land Desktop 2008
2 REPLIES 2
spammie1
3545 Views, 2 Replies
Land Desktop 2008
Is it possible to install Land Desktop 2008 on a Win7 64 bit machine?  I get "This is 32-bit AutoCad Land Desktop 2008.  It can not be installed on 64-bit Windows" when trying to install from disk.
Thank you
2 REPLIES 2
pendean
in reply to: spammie1
Not an option: 32bit AutoCAd in 32bit Windows (downgrade Win7 from 64bit to 32bit perhaps)), 64bit AutoCAD in 64bit Windows.
Look for a third party software called LONGBOW, it may help (not guarantees): there are also numerous hacks posted all over the web on how to try and get what you want to happen. Start searching.
spammie1
in reply to: pendean
Thank you pendean - Longbow worked.  I spent hours trying to get XP mode working in WIN7 but could not get it to work because I have a AMD Bulldozer Processor (FX-8350) even with the hotfix that MS has published: http://support.microsoft.com/kb/2519949.
After installing Longbow, you need to copy the Land Desktop media to local HDD (straight copy not an image) and then run Longbow (won't work when installing LD8 from DVD media).  Thanks again.
