Is it possible to install Land Desktop 2008 on a Win7 64 bit machine? I get "This is 32-bit AutoCad Land Desktop 2008. It can not be installed on 64-bit Windows" when trying to install from disk.
Thank you
Solved by spammie1. Go to Solution.
Thank you pendean - Longbow worked. I spent hours trying to get XP mode working in WIN7 but could not get it to work because I have a AMD Bulldozer Processor (FX-8350) even with the hotfix that MS has published: http://support.microsoft.com/kb/2519949.
After installing Longbow, you need to copy the Land Desktop media to local HDD (straight copy not an image) and then run Longbow (won't work when installing LD8 from DVD media). Thanks again.
