AutoCAD Land Desktop
Valued Contributor
RCWisehart
Message 1 of 3 (1,270 Views)
LDT Object Enabler Installation
1270 Views, 2 Replies
03-22-2012 04:07 AM
Windows 7 64-bit OS
Installed Civil 3D 2012
Installed LDT 2009 with SP3
As indicated in the Knowledge Base, I attempted to installed Raster Design Object Enabler 32-bit, rather than the 64-bit Object Enabler.
In the installation process, I make it to the point of being able to select the application to which it is to be applied. Click Next and I'm notified that I need Admistrator rights, however, I'm the only USER login and I am the Administrator.
H E L P   P L E A S E  ! ! !
Jeff_M
Message 2 of 3 (1,264 Views)
Re: LDT Object Enabler Installation
03-22-2012 09:52 AM in reply to: RCWisehart
In Windows Explorer, browse to the installer exe file. Right-click and choose "Run as Administrator".
Valued Contributor
RCWisehart
Message 3 of 3 (1,261 Views)
03-22-2012 12:08 PM in reply to: Jeff_M
Thanks! That worked, now I can see images in existing drawings. Any idea when or if they will fix the MAPINSERT command?
You are not logged in.
Ask the Community
