Hi Darron,
This type of problem sounds hardware dependent to me.
Check your video drivers.
Check if there is any possibility of overheating.
You may care to review other software you have running to see if any of
those could affect your work environment.
Laurie Comerford
CADApps
www.cadapps.com.au
"Darron Agawa" wrote in message
news:4092932d$1_1@newsprd01...
> Not to mention the unending pauses w/my Properties window open, I'm having
> some other odd problems occurring while running LDT 2004 and/or LE Map.
For
> some reason my Properties window will show that something is selected like
a
> 3D polyline, a viewport, or a 2D polyline, when in reality nothing is
> selected. Other times, my Properties window will be completely blank as
if
> something was selected whose properties cannot be changed.
> This "ghost" object makes the Properties window completely useless because
I
> can't select any object to modify its properties. I've also seen this
> affect other LDT commands like listing a breakline, but I'm sure it
affects
> a lot more that require selecting an AEC object.
> I've tried doing everything short of completely unistalling and installing
> everything over again. The only thing that works is closing the drawing
and
> reopening, but the same thing happens 30-40 mins. later. Quite
frustrating!
> Anyone ever seen or heard of this?
> Darron K. Agawa
> Civil Engineer
> Town of Windsor
