AutoCAD Land Desktop
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
LDD Companion 2007 errors running on Win 7 64
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The computer is an Intel I7 CPU with 8 Gig RAM and an Nvidia Quadro FX 1800 running Windows 7 Pro 64 fully patched.
I've done the install but when the software is run I am getting error messages and no the some menus are not opening.
He has the new version of the LAND DESKTOP COMPANION but he needs to have the 2007 version running for a few reasons. There are projects that are in the middle of being worked on that were started in 2007. The other big reason is that it's been 3 years since the last major update of software and there is a big learning curve. Projects need to get done so there isn't time to train on the latest version so they need to stick with 2007 for a while.
He also needs to run Windows 7 64 instead of Windows XP 64 because of directory issues with our NAS.
Here are some errors when it first loads up:
Customization file loaded successfully. Customization Group: LAND
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: CIVILDESIGN
Customization file loaded successfully. Customization Group: SURVEY
Customization file loaded successfully. Customization Group: EXPRESS
Regenerating model.
Initializing....
C:\Program Files (x86)\Autodesk Land Desktop 2007\AcMapWorkspace.arx cannot
find a dll or other file that it needs.
.Failed.
AcMapWorkspace.arx Load Failed
C:\Program Files (x86)\Autodesk Land Desktop 2007\AecCMapCogoCmds50.arx cannot
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD menu utilities loaded.
C:\Program Files (x86)\Autodesk Land Desktop 2007\aeccapp50.arx cannot find a
; error: ARXLOAD failed
Command: COMMANDLINE
Does anyone know how I might be able to fix the issue so things will work on the new machine?
Thanks for any help.
Darren.
Re: LDD Companion 2007 errors running on Win 7 64
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
check out the following blogs....
http://social.technet.microsoft.com/Forums/fi-FI/w
http://social.technet.microsoft.com/Forums/en/w7it
hope this helps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The user has a 2009 version of AutoCAD that I will install on Windows 7 so it should be fine. He was saying that the format from 2007 to 2009 is the same so they should be able to do what they need to. AutoCAD 2010 is a different format and would have been harder to work with. Since they have 9 they are good to go.
They actually need AutoCAD 2004 for some older systems they use so the Win XP virtual machine running in Windows 7 should work for that.
Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Finally got LDD 2007 to work on Windows x64 (Windows7)
(go the ACMapWorkspace.arx error loading, etc. before)
Install DirectX 9.0c runtime
http://www.microsoft.com/download/en/details.aspx?
I racked my brains to figure this one out. Worked on my laptop, but not the other CAD workstations.
Only difference is I had Microstation on my PC, which installs DirectX 9 as a prerequisite program.
Also edit the "acad.exe config" file to use only .Net v2.0.50727 otherwise Layer Manager can crash LDD
<configuration>
<startup>
<!--We always use the latest version of the framework installed on the computer. If you
are having problems then explicitly specify .NET 2.0 by uncommenting the following line.
<supportedRuntime version="v2.0.50727"/>
</startup>
<runtime><assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1"><probing privatePath="Fdo\bin"/></assemblyBinding></runtime
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Same issue slightly different, I need to get LDD 2006 to run on a Windows 7 64bit system. After install, same errors above.
Autocad runs but with little LDD functionality. Again same errors.
I will try the Directx 9.0c install and since 2006 uses dotnet 1.1 with sp1 (which I did install, that was fun too.....not) will I have to modify the acad.exe cfg file the same way except point to dotnet 1.1?????
Anyone manage to get LDD2006 to run on Windows 7 64bit????
Yes I know we need to upgrade but like other things in life, I cannot control this one. Required for a contract with a govt. agency.... now you know!!!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The .NET has to do with Layer Manager in 2007 (which causes LDD to crash...fun) and anything else that uses .NET for the backend You probably need to change the acadexe config (if that exists there to use .NET v1.1.4322, not sure if it's the correct version or not).
The DirectX 9 had to do with all the arx issues.
Re: LDD 2006 errors running on Win 7 64
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Just an update
Followed your recommendation and installed Directx9----no change
Then noticed that in AutoCAD under options everything pointed to C:\Program Files\.........
However when it was installed a directory called C:\Program Files (86)\..... was created and that is where the files were at.
So, revised all of the file paths in AutoCAD to point to that directory that had calls to "C:\Program Files\....." to C:\Program Files (86)
Most of the errors are gone
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Just an update
Did the edit of the acad.exe.config file to use only net 1.1-------------------------- NO CHANGE same errors as before.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Back in the forums someone suggested this: (LDD 2006 seems like a real pain...2007 was a little better)
1. Check your support paths (in AutoCAD and in the SDSK.DFM file) - make sure there are no references to older paths (like from LDT2005)
2. This usually means there is something messed up with the current .NET install. Try running a repair on it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This error can occur after reinstalling or uninstalling some Windows applications. The AC1ST16.DLL is probably not missing, only AutoCADcannot find it.
To set Windows environment variables, right-click on the 'My Computer' icon, select 'Properties'. In the 'System Properties' dialog, go to the 'Advanced' tab and click the 'Environment variables' button. You can modify the User- (for you) or System- (for all) variables.
Go to Windows System settings of your computer and in the Environment variables, make sure that the PATH variable contains the folder name C:\Program Files (x86)\Common Files\Autodesk Shared (without the backslash at the end, you can remove it using the Edit button).
If the file is really missing, you have to reinstall or repair your AutoCAD installation.
