AutoCAD Land Desktop (Read Only)
LDD 2009 Description Keys Issue
2 REPLIES 2
chrisdavis5201
1345 Views, 2 Replies
We are having a problem with Description Keys in LDD 2009. I have searched the forum and not found a matching issue.
We have created a DWT file that has the prototypes set up, the description keys, label styles, point styles, layers, and the pathing to all the symbols. The problem is that the dwt will work on the machine it was created on, but anyone else that starts a drawing with the same dwt (saved as a dwg) will not get the same results. When anyone else tries to import the points, no symbols come in and everything imports on the current layer. Both computers have the same pathing in the "support file search" in the "Files" tab of the Options dialog box.
Chris
2 REPLIES 2
Jeff_M
in reply to: chrisdavis5201
LDT does not save the DescriptionKeys in the drawing. These are saved in a MDB file in the project's "cogo\DescKey" folder.
Thank you so much for that. Can you tell me how to prevent point labels from rotating back to their original position if you have to reinsert them?
