AutoCAD Land Desktop (Read Only)
Inserting points to autocad from land desktop.
1 REPLY 1
cvg-man
645 Views, 1 Reply
I having trouble inserting data points from land desktop into an autocad drawing.
I am wblocking the points and linework in land desktop 7.
Next I am inserting the block into autocad 7.
I can see the points in the block when I choose the block but after I insert the block all I can see is
my line work.
It's like a setting is wrong or something.
I have done this numerous times in earlier versions.
Any help?
1 REPLY 1
omc-usnr
in reply to: cvg-man
LDT points are an AECC intelegent object, and cannot be used in plain ACAD.  If you have an object enabler for the version of ACAD you are using, you can see the points but not interact with them.
If you did this in "earlier versions" they must have been SDSK points (prior to ADSK aquireing SDSK/DCA).
Reid
