AutoCAD Land Desktop (Read Only)
Message 1 of 8
FOXINC
387 Views, 7 Replies
IMAGE DETACH
I HAVE A FEW DWGS THAT I CAN'T DETACH THE IMAGES ALL I COULD DO IS DELETE THEM, THE PATHS STILL EXIST IN THE DWG!
JOHN, I SAW ACTUALLY BACK IN 04 YOU POSED A RUI FILE IS THIS STILL AROUND?
LDT2007
7 REPLIES 7
Message 2 of 8
in reply to: FOXINC
Search this NG on the web side for RUI and Jeff Mishler. He's the author. He
does hang out on the C3D NG from time to time now but I bet the code is
still on this NG.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008, LDT 2008, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
wrote in message news:5825649@discussion.autodesk.com...
LDT2007
Message 3 of 8
FOXINC
in reply to: FOXINC
THANKS JEFF... (WHAT IS NG)... UNDERSTOOD CIVIL 3D....NOT SURE WHERE TO LOOK.
EMIAL ME IF YOU'D LIKE CCADIEUX@FOXASSOCIATESINC.COM
CHAD
Message 4 of 8
in reply to: FOXINC
The Civil 3D NewsGroup (NG).
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
wrote in message news:5825743@discussion.autodesk.com...
LOOK.
CHAD
Message 5 of 8
FOXINC
in reply to: FOXINC
OK SO I LOADED THE LSP FROM JEFF. http://discussion.autodesk.com/thread.jspa?messageID=3000487
MADE THE REVISION. IT SAID "Command: RUIMAGE
0 images found...removed 2 unreferenced images.
Command:"
YET STILL GET THE FOLLOWING IN MY IMAGE BOX SEE ATTACHEMENT
OK BEFORE I POSTED THIS I CHECKED THE BOX AGAIN AND THEYA RE GONE!!!! IT TOOK A FEW MINS TO I DUNO WHAT BUT I GUESS IT WORKED!
Message 6 of 8
in reply to: FOXINC
I know Jeff's routine worked for me. Something strange is going on. Is the
image in EX-1.dwg? Do you have that image defined inside a block in the dwg?
Is it in paperspace?
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
wrote in message news:5825965@discussion.autodesk.com...
Command:"
Message 7 of 8
stacy.dunn
in reply to: FOXINC
Some images that include certain characters cannot be detached from the external references pallet. You can rename the image or use the classicimage or -image commands to remove it.
Message 8 of 8
FOXINC
in reply to: FOXINC
EX-1 IS THE EXISTING TOPOGRAPHY THAT IS OVERLAID XREF'D INTO THE BASE DWG. THE 2 IMAGES THE 00 AND THE DS WERE THE 2 IMAGES AND SOME IN OTHER DWGS THAT NOTHING COULD BE DONE ABOUT. THIS WAS/IS A NEW PROBLEM, THAT HAS JUST APPEARED IN THE LAST FEW WEEKS... FIGUES SINCE WE ARE GETTING 08 SOON.
