Not to start over again Dixie, but you could follow the steps that have been
laid out for you in the other thread - measuring volume.
I'm going to lay on you the same thing I did there;
This is found in Help under the following Title;
Calculating Composite Volumes
Use the Composite method to calculate volumes both for a defined stratum and
parcels within the area of that stratum. For more information about the
Composite method, see Using the Composite Method.
Related topics
Defining a Stratum
Changing the Composite Volume Settings
Calculating Total Site Volumes Using the Composite Method
Calculating Parcel Volumes Using the Composite Method
Look up those four Blue Underlined Titles, and that should get you started
with understanding what you're attempting to handle - all by yourself.
HTH
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
LDT/CD-2K4
AMD Athlon 64 X2 Dual 2.01GHz
XPPro 32bit SP2
2GB RAM
Dual WD800JD Hard Drives - 149GB Nvidia Stripe
Nvidia Quadro FX 1300 128MB
Dual ViewSonic 19-inch VA902b monitors
wrote in message news:5179388@discussion.autodesk.com...
im assumeing that that is the same thing i need to do to calculate volume of
dirt moved from original site to finished site, not to familier with land
desktop how would i do this.
