AutoCAD Land Desktop (Read Only)
How do calculate the area of a hatch
10 REPLIES 10
Message 1 of 11
45920 Views, 10 Replies
I have a rather irregular shaped site plan with a hatch area where new pavement is going to be layed. Theres several curves and what not so doing it the long way of picking corners will be a hassle. I assume there must be a faster way? Picking Area-Object doesn't seem to work to well.
I have 2004
10 REPLIES 10
Message 2 of 11
Use the attached to get a pline boundary from any hatch.
John
Message 3 of 11
Exactly the same answer I just gave in the Drafting Group.
"John Mayo" wrote in message
news:5104931@discussion.autodesk.com...
John
Message 4 of 11
Excellent Advice!! At least in my opinion 😉
John
Message 5 of 11
"Great minds..." 🙂
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
C3D/LDT/CD/SVY-2K6
Intel P4-3.00GHz
XPPro 32bit SP2
1GB RAM
Nvidia GeForce2 Ti 64MB
news:5104980@discussion.autodesk.com...
John
Message 6 of 11
Thanks everyone. I posted in both wasn't sure who would answer me first.
Message 7 of 11
If you hatched the area with a non-polyline boundary, you can turn off the
hatch and create polyline boundary by using the BOUNDARY command. Then just
check its properties for the area or use LIST.
IF the boundary command doesn't work because you have a small gap, you could
copy the objects to an open portion of your drawing and join them with a
multiple pedit-join command giving a fuzzy distance. Below is a button
macro for joining lines, arcs, and polylines into polylines. It will ask
for a fuzzy distance in case you have small gaps. I prefer to copy first so
that I don't change the original items, but you can always run PJoin and
them move it back using snaps.
PJoin
Converts lines to polylines and joins them. Assumes that they are
connected.
^C^C_peditaccept;1;_select;_auto;\_Pedit;_m;_p;;_j;\;
For the PJoin icon, I just use the regular Pedit icon, but have the button
in a different location (My macros toolbar) so I can tell them apart.
If you have LDT or maybe some other vertical package and have lost your
hatch boundary, but still have your hatch, you can create a boundary by
using AECLINEWORKSHRINKWRAP. I mainly use it for creating boundaries around
point groups in LDT, but I just tried for a hatch and it worked file.
Brad
wrote in message news:5104851@discussion.autodesk.com...
I have 2004
Message 8 of 11
along with the other excellent advice given, I believe the shrinkwrap
command also works on hatch objects.
Doug K
LDT 2005, XP Pro 2002 sp2, P4 2.40GHz, 1 GB RAM, Dual 19" Dell LCD, NVIDIA
GeForce FX 5700LE, Left Handed Kensington Trackball, Happily Married
w/Children
I have 2004
Message 9 of 11
Hi, i have a question. I have a diagram in autocad, i need to calculate the area using macro so that i get a message of the total area
Message 10 of 11
pendean
PROPERTIES command usually lists areas of a selected hatch.
LIST command does the same thing.
Still need a "macro"?
Message 11 of 11
Ya i still need.bcoz i hv multiple areas of same type which are scattered and i need the total area at one time
