AutoCAD Land Desktop
Valued Contributor
Topher
Message 1 of 8 (169 Views)
How do I do a road widening?
169 Views, 7 Replies
10-20-2004 07:51 AM
I'm trying to do a preliminary estimate for widening a road to include a left turn lane. On the right, there will be a new shoulder, on the left, the road will be widened from the ex. edge to the new edge, then a 1.5m shoulder & a ditch.
I thought of creating a template & then attaching subassemblies, with the first left transition being the existing edge of pavement where the widening subassembly attaches & the first right transition being the existing edge of pavement where the new shoulder would go. It works for the shoulder, but subassemblies can't be streched, so the road wideing won't work.
The only thing I can think of is to create a template for the road wideing with the ref. point being the ex edge of road & the first transition being the proposed edge of road. I'd then have to do something similar for the shoulder side & create sections for the wideing & sections for the shoulder & then add the quantities together.
Is there a better way?
I sure wish subassemblies could be stretched.
Chris
*robert steltman
Message 2 of 8 (169 Views)
Re: How do I do a road widening?
10-20-2004 08:39 AM in reply to: Topher
Use transition profiles and transitions in your templates. There is a routine in Road Design Tools, Road Widening, that will create the 2 transition profiles that represent your existing and proposed edge of pavement, it also ddraws the widening on the section with labels for offset and elevation and finnally it generates a reportshowing offset elevations and grades for each station. View the AVI that shows the process including attaching the alignments and profiles in Design Control http://www.rsteltman.com/content/downloads/road_wide.avi . Road Design Tools is part of the Road Tools suite of routine that enhances Civil/Design for Road Designers. Download the FREE 30 day fully functioning evaluation version http://www.rsteltman.com/ "Topher" wrote in message news:4357985.1098283929525.JavaMail.jive@jiveforum1.autodesk.com... > I'm trying to do a preliminary estimate for widening a road to include a left turn lane. On the right, there will be a new shoulder, on the left, the road will be widened from the ex. edge to the new edge, then a 1.5m shoulder & a ditch. > I thought of creating a template & then attaching subassemblies, with the first left transition being the existing edge of pavement where the widening subassembly attaches & the first right transition being the existing edge of pavement where the new shoulder would go. It works for the shoulder, but subassemblies can't be streched, so the road wideing won't work. > The only thing I can think of is to create a template for the road wideing with the ref. point being the ex edge of road & the first transition being the proposed edge of road. I'd then have to do something similar for the shoulder side & create sections for the wideing & sections for the shoulder & then add the quantities together. > Is there a better way? > I sure wish subassemblies could be stretched. > > Chris
*Joe Bouza
Message 3 of 8 (169 Views)
10-20-2004 10:32 AM in reply to: Topher
Hi Topher, Some may disagree, but I just take the -EX eop as a 3dpoly use a GO to project a cross slope, -make a temp surface from the GO - project the proposed eop onto the surface -measure ACAD points every 25-50 feet -convert to LDD point with a label style that adds .5 ft to get: TC 100.50 BC 100.00 and I'm done in about 5 minutes ready to widen the next section Joe "Topher" wrote in message news:4357985.1098283929525.JavaMail.jive@jiveforum1.autodesk.com... > I'm trying to do a preliminary estimate for widening a road to include a left turn lane. On the right, there will be a new shoulder, on the left, the road will be widened from the ex. edge to the new edge, then a 1.5m shoulder & a ditch. > I thought of creating a template & then attaching subassemblies, with the first left transition being the existing edge of pavement where the widening subassembly attaches & the first right transition being the existing edge of pavement where the new shoulder would go. It works for the shoulder, but subassemblies can't be streched, so the road wideing won't work. > The only thing I can think of is to create a template for the road wideing with the ref. point being the ex edge of road & the first transition being the proposed edge of road. I'd then have to do something similar for the shoulder side & create sections for the wideing & sections for the shoulder & then add the quantities together. > Is there a better way? > I sure wish subassemblies could be stretched. > > Chris
Valued Contributor
Randy S
Message 4 of 8 (169 Views)
12-06-2004 05:50 PM in reply to: Topher
what do you mean by "GO"
Active Contributor
DannyCounts
Message 5 of 8 (169 Views)
12-06-2004 07:46 PM in reply to: Topher
Robert, I don't know if you saw my recent post on varying crossgrades of an existing road. I wonder if you have any tools that will handle this. I have to widen a road but as the EP moves out, it needs to hold the varying crossgrade of the exisitng road. I don't think I can accomplish this with templates can I? Do you have any tools that will make this easier?
Active Contributor
DannyCounts
Message 6 of 8 (169 Views)
12-06-2004 07:49 PM in reply to: Topher
I am attempting to do the same thing with a road widening that you say, but I am confused as to what is a GO. What do you do if the existing cross slope varies? How do you project that?
*Brian Hailey
Message 7 of 8 (169 Views)
12-07-2004 06:55 AM in reply to: Topher
Randy, A GO is a Grading Object. -- Brian Hailey LDT2005 C3D2005 XP Pro - SP 2 P4 2.8GHz 1.00 GB of RAM "Randy S" wrote in message news:7589428.1102384250566.JavaMail.jive@jiveforum1.autodesk.com... > what do you mean by "GO"
*robert steltman
Message 8 of 8 (169 Views)
12-07-2004 09:41 AM in reply to: Topher
There is a routine in Road Design Tools, Road Widening, that will place transition profiles for existing and proposed edge of pavement on profile, show the widening on the sections and generate a report showing existing and proposed conditions.View Road Widening AVI http://www.rsteltman.com/content/downloads/road_wide.avi . Road Design Tools is part of the Road Tools suite of routine that enhances Civil/Design for Road Designers. Download the FREE 30 day fully functioning evaluation version http://www.rsteltman.com/ "Randy S" wrote in message news:7589428.1102384250566.JavaMail.jive@jiveforum1.autodesk.com... > what do you mean by "GO"
