"qdesigns" <If
href="mailto:mike@andrewsengineering.net">mike@andrewsengineering.net>
wrote in message
href="news:f0d9bba.0@WebX.maYIadrTaRb">news:f0d9bba.0@WebX.maYIadrTaRb...
you import the FG vertical alignment into your profile, it does tell you the
high or low pvi elevation & station. However if you are doing a vertical
curve between to tangents with both a negative or a positive slope in the same
direction then there is no such thing as a high or low
pvi.
"zuzi" <pnichols@lawco.com>Tim,
wrote in message
href="news:f0d9bba.3@WebX.maYIadrTaRb">news:f0d9bba.3@WebX.maYIadrTaRb...
when you import your fg profile select yes when promted to label vertical
curves and the sta and elevation of low / high points will be plotted for
you.
