If you are trying to export #,X,Y values, make sure your export format is
set to match the values in your points. If you try to export a Z value when
you do not have one, it can lock up the machine.
Also, be sure you have run "check points" and everything lists fine in list
points before you export. Lastly, save the DWG before you try and export in
case it crashes.
HTH
Walter
"Glenda Snively" wrote in message
news:5061508@discussion.autodesk.com...
Has anyone had any problems exporting points from a drawing? I have even
blocked the points and drawing and created an entirely new project from the
blocked drawing. When I try to export points it brings up the dialogue box
and just freezes the entire drawing and the only way to get out of the file
is to Ctrl-Alt-Del. This can be a tremendous waste of time. Any help out
there? I have even moved this drawing to another computer and it locks it
up too. I am running Windows XP and LDD2.
Glenda
gsnively@nc.rr.com
