(I'm now wondering if the OE version will be complete after what I saw earlier today?)
And give me a clue on what you wish to achieve from this?
Would it be Staking Points?
If that's the case, then I would recommend you get familiar with LDT's Cross Sections a little further. It sounds like you may have already familiarized yourself with them.
Do your Templates utilize Point Codes?
They will enable the staking points (ROW Line, Walk Subgrade, Curb Subgrade, C/L Subgrade, etc. - see the attached PNG) to be quickly (and accurately) positioned both horizontally AND vertically. You can even accommodate transitions for Knuckles and Lane Widenings through the Templates. I always build my Templates so that I use the Edge of AC Paving as the Transition Alignment. Due to the fact that most agency's Gutter Width is around 1.5 to 2 feet towards the Centerline, away from the Gutter Flowline.
If it's not Staking Points you need yet, maybe I got the idea placed in your mind when you WILL need them. 🙂
HTH - if I didn't mis-understand the reasoning behind this procedure.
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
C3D/LDT/CD/SVY-2K6
AMD XP 3200+ 2.2GHz
XPPro 32bit SP2
1GB RAM
Nvidia GeForce4 MX 4000 128MB
