From memory in early versions of Land Desktop they are individual files.
I've just checked R2007 and R2008 where the format are stored in a binary
file found in directories like:
"C:\Documents and Settings\All Users\Application Data\Autodesk\AutoCAD Civil
3D Land Desktop Companion 2008\R17.1\Data\format manager" You can check the
path from the [Project] menu
In the [Points][Import/Export][Format Manager] form, the Remove command is
greyed out in both versions on this computer.
By why bother? The program defaults to the last used format and sooner or
later you will get a file from an external source which you need to use and
which won't be your standard format.
Laurie Comerford
CADApps
www.cadapps.com.au
www.civil3Dtools.com
wrote in message news:5569677@discussion.autodesk.com...
Is there a way to remove the standard point export formats if a company uses
just one style?
