My drawing is transformed and orientated to a lat/long coordinate system,
and also transformed to the Ohio state plane. I did this via project setup.
And map isn't recognizing the LDD coordinate system, or the transformation.
"James Murphy" wrote in message
news:5612260@discussion.autodesk.com...
How about using the Track Coordinates and digitizing with the map tools? You
need to assign a coordinate system to your dwg. If you can't get that to
work (Track Coordinates) then transform your dwg to a lat/lon coordinate
system.
Murph
The world is not FLAT so why is your GIS data?
http://map3d.wordpress.com
"Dennis Hyman" wrote in message
news:5612190@discussion.autodesk.com...
No. What I need to do is to draw a line from one longitude & latitude to
another longitude & latitude. The deal is is that I have an engineer that
needed long's and lat's on a proposed building, which he placed on a
background of a USGS quad sheet (in Ohio). The FAA wants distances from the
building corner to 3 different points at a nearby airport, but the points
are described in longitudes and latitudes. I can list longs and lats, but I
need to draw lines from one to another.
"Joe Bouza" wrote in message
news:5611684@discussion.autodesk.com...
Hi Dennis, would placing points by "Geodedic Direct" help then you could
draw line by points?
Joe
news:5611490@discussion.autodesk.com...
Is it possible in LDD 2004? If so, how do I go about it? I have my site in
the correct zone, and transformed to the state plane system. I'm within 1
second of the quad sheet.
Dennis Hyman (aspiring PLS)
Cad Tech. - Survey Dept.
Stock & Associates Consulting Engineers
Chesterfield, Missouri
LDD 2004, Civil, Survey, Map
2.4 Ghz P4, 512 MB RAM
GeForce 4 MX 440 Graphics Card
