I am having a problem figuring out how to get the desc. key to finish drawing a line when another point description is collected just before the original line has ended (i.e. you collect a back of curb, and then a edge of pavement, then you end the back of curb and the line does not connect to the last point).
Also for points that extra descriptions are given for (i.e. FL 4', where the description key is FL*) are connected in the order the points are collected not by the description key. For example you collect a fence line as FL 4' and then collect a ground shot, then continue the fence. This causes the line to connect from the fence to the ground shot and back to the fence.
