John, when you enter filed data manually into LDT it creates a batch file
exactly like the one cwls is creating by hand. There is a command "Run batch
file" in the Survey menu which runs the survey command in the file all at
once. There were many times when we were still entering data this way that
some errors were found in the input data, all we need do was edit the batch
file and re-run it. This creates the points.
Jeff
"John Mayo" wrote in message
news:5788532@discussion.autodesk.com...
Okay, but I don't think LDT knows how to interpret this out of the box,
NE 67 2008890.842 590014.160 IP "FND 1 W/JONES CAP"
NE 12 2001052.318 590076.756 MAG "FND INT. RD"
STA 12
BS 67
AD 14 180.1543 423.165 SPK "SET 8"
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008, LDT 2008, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
wrote in message news:5788477@discussion.autodesk.com...
No, your not following.
The file I posted previously is an example batch.txt file that creates
points.
End of story. That is how points are created.
It has worked in the past with other projects. Maybe this file is corrupted
somehow.
Lets drop this topic since this is not helpful for this problem.
