I thought it was Jeff. You may find it if you search this NG on a web
browser. I believe Terry has posted it a few times. With a little luck he
may chime in as well. It worked fantastic on a similar situation here once.
Glad you found a solution and thanks for providing feedback with the
Overkill method. I have been reluctant to use overkill in the past on
anything but linework because it has renamed blocks on me when I used it in
the past. It took every block in my dwg & renamed each block with a
different name (i.e. MH became MH1, MH2, MH3, etc.). That messed up a few
things in my project at the time.
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2007, LDT 2007, Raster Design 2007
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
"Jeff Clark" wrote in message
news:5563781@discussion.autodesk.com...
Thanks Guys!!
I have the original TXT points files from the client, so I can always read
them back in.......
I inserted ALL points into a new drawing.
Then I ran the Express tool OVERKILL. It worked beautifuly. 5000 points
became 2500 real fast.
Then I ran 'check points' turning on the 'delete all points not in the
current drawing' option.
Packed the data base and Wa-La! I have a clean project!! How cool is that!
Thanks again folks.
-JC
John - I couldn't find that routine at Dotsoft. Is it in the Free Stuff
section?
news:5563076@discussion.autodesk.com...
I have a project data base (from a client) with hundreds of duplicated
points.
The only difference in the dups is their point numbers.
Has anyone see a way to delete these dups and only leave one instance of
each point?
Jeff Clark
Designer III
Consulting Engineer Services
Sewell, NJ
Acad 2006 LDT w/CD
