AutoCAD Land Desktop (Read Only)
Default Units Setting
2 REPLIES 2
209 Views, 2 Replies
Hi --
I cant figure out this problem for the life of me, yet it seems that there may be a simple fix.
I am using AutoCad LDD 2i. The default units comes in as architectural. I change the default setting to decimal with 4 decimal places. Several minutes of diligently working on my project and I look and my units are back to architectural. This also happens when I first open the project and save it with the units being decimal. Does anyone know how I can permanently change the units to decimal and not architectural?
Bill
2 REPLIES 2
try typing "aecdwgsetup" at the command line.
It should give you various options that will let you lock down your
units.
Jon
Thanks "J"
That seemed to work. Thanks
