AutoCAD Land Desktop (Read Only)
326 Views, 4 Replies
DJ 1050C
DON'T KNOW WHERE TO POST THIS BUT HERE GOES... SOMETIMES WHEN WE PLOT TO OUT 1050C WE GET A "30 NESTING" MESSAGE... ANY CLUE WHERE THIS SETTING IS OR WHAT IT IS?
4 REPLIES 4
auzzie2776
i would update your print driver from HP web site. most error messages occur from old drivers and software. while your at it, update your LDD and OS to latest service packs and hot fixes
You have to turn nesting off on the plotter. This is a common feature that
allows the plotter to determine if it can fit two or more plots on the
roll/sheet to save paper. On the 1050, I think you have to go to the Setup
menu & Queue & Nesting Options should be listed.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008, LDT 2008, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
wrote in message news:5825972@discussion.autodesk.com...
WHAT IT IS?
And I imagine that counts down.
In the printer settings (on the machine itself), there is a menu that allows
you to turn on and off the nesting. *goes into print room and checks*
In the menu, go to the bottom icon, which is the "Printer Setup Menu". Hit
enter, and the top menu is "Queueing & Nesting...". Hit enter, scroll down
to "Nesting=", and if it's on, hit enter, select off, hit enter, then hit
the "TOP" button on the machine. That will turn off the nesting.
Dennis Hyman (aspiring PLS)
Cad Tech. - Survey Dept.
Stock & Associates Consulting Engineers
Chesterfield, Missouri
LDD 2004, Civil, Survey, Map
3.0 Ghz P4, Dual processor, 1 GB RAM
GeForce 4 MX 440 Graphics Card
WHAT IT IS?
Dennis gets the gold star for content. 😉
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
"Dennis Hyman" wrote in message
news:5826115@discussion.autodesk.com...
WHAT IT IS?
