AutoCAD Land Desktop
*Don Reichle
Message 11 of 12 (107 Views)
Re: Creating a profile with cl points
10-05-2004 09:29 PM in reply to: bigred1234
Obviously this profile will never find its way anywhere near being used for the Cross Section module. -- Don Reichle Hacker Engineering, Inc. "King of Work-Arounds" "Adam Davis" wrote in message news:41630cd9_1@newsprd01... > And just one more 3rd Party solution - AutoChart > > AutoChart is an AutoCAD extension that automates the production of > North-Up > and Alignment sheets. It is not directly linked to the design process > within > the Civil series instead supplying automation of sheet creation within the > AutoCAD Map environment. It was originally designed for the hydrographic > industry but has recently been used on other types of corridor mapping > environment. > > The basic process is > 1) Create an alignment or area object. > 2) Create panels along alignment or in area (These can be moved at will > after automatic generation) > 3) Create Chart Set corresponding to previously created panels. > 4) Create Grid/Graticules within Chart Set. > 5) Xref Data into Chart Set (for data that needs no textual rotation) > 6) Insert (and rotate) Data into Chart Set (for that needs textual > rotation) > 7) Create Profile(s) based upon Plan Panel. > 8) Add Other specifc data types such as Relative profile data, event data > etc. > > AutoChart is not limited to one panel or profile per sheet and can display > multiple plans or profiles using either identical or different geographic > locations. Sheets/Profiles can be created left-to-right or right-to-left. > All commands work in Meters, US Survey Feet and International Feet. > > There are several demonstration videos available on our website > North-Up Example - http://www.wishsoftware.com/NorthUpExample.exe > Pipeline Engineering Example - > http://www.wishsoftware.com/AutoChartEngineeringExample.exe > Cable Route Alignment Example - > http://www.wishsoftware.com/CableExample.exe > Pipeline Inspection Example - > http://www.wishsoftware.com/PipelineInspectionExample.exe > Sidescan and Sub-Bottom Example - > http://www.wishsoftware.com/SBPExample.exe > > > It must be noted that AutoChart is not specifically integrated into Land > Desktop DTM functionality (as there are specific tools within the > hydrographic industry that can cope with upwards of 200 million points - > see > http://www.ivs3d.com/products/fledermaus/index.html) and sits outside the > design process. It is a tool to automate the production of charts using a > wide variety of data types. > > Regards, > > Adam Davis > > > -- > Adam Davis > Wish Software Limited > 5 Biggar Road > Silverburn > EH26 9LQ > UK > tel: +44 (0)1968 670 899 > fax: +44 (0)870 220 0875 > mailto:adam@wishsoftware.com > www.wishsoftware.com > "bigred1234" wrote in message > news:20532535.1096928435202.JavaMail.jive@jiveforum2.autodesk.com... >>I am trying to create a profile by just using the points and not creating >>a >>surface, is there an easy way to do that? Any help would be greatly >>appreciated. > > > >
*cadguy
Message 12 of 12 (107 Views)
10-08-2004 07:32 AM in reply to: bigred1234
One more method. If you are only interested in the profile place, points with a constant elevation around the center line shots. make a breakline of the centerline shots then create a surface. the surface will be accurate at the centerline only!. Then pull the profile. I teach surveying and use this method to create a profile and cross sections from level notes. As long as you create breaklines using "good" data then the sections and profiles will be accurate. "bigred1234" wrote in message news:20532535.1096928435202.JavaMail.jive@jiveforum2.autodesk.com... >I am trying to create a profile by just using the points and not creating a >surface, is there an easy way to do that? Any help would be greatly >appreciated.
You are not logged in.
Ask the Community
