Hi Laurie,
Actually, in the properties window, you can select what type of object you
want to edit out of all the selected objects. There is a pull down list at
the top that will let you select any of the object types selected.
Brian
"Laurie Comerford" wrote in message
news:412ba8cb$1_3@newsprd01...
> Hi,
> This will only work if all the objects on the layer are text.
> The Land Desktop tools I would use are
> [Utilities][Selection Set] SS from the command line to select all the
text
> on the layer.
> [Utilities][Replace Blocks/Text]
> Laurie Comerford
> CADApps
> www.cadapps.com.au
> "Russell Dieges" wrote in message
> news:412b5e41$1_3@newsprd01...
> > Isolate the layer
> > Select everything
> > Open properties (CTRL+1)
> > Change the Height value to your new text size
> > HTH
> > Russell
