AutoCAD Land Desktop (Read Only)
Change text size
5 REPLIES 5
6256 Views, 5 Replies
Change text size
Is it possible to change text size on a specfic layer. I have a layer that text is too small to read and wish to change all the text using one command, ie. present text size 10 m, change to 20 m height.
5 REPLIES 5
Isolate the layer Select everything Open properties (CTRL+1) Change the Height value to your new text size HTH Russell
qselect -- John Michalik Drafting and Design LDD/CAD Development & Standards johnm@weissereng.com "explorenb" wrote in message news:30444107.1093361074794.JavaMail.jive@jiveforum2.autodesk.com... > Is it possible to change text size on a specfic layer. I have a layer that text is too small to read and wish to change all the text using one command, ie. present text size 10 m, change to 20 m height.
Hi, This will only work if all the objects on the layer are text. The Land Desktop tools I would use are [Utilities][Selection Set] SS from the command line to select all the text on the layer. [Utilities][Replace Blocks/Text] -- Laurie Comerford CADApps www.cadapps.com.au "Russell Dieges" wrote in message news:412b5e41$1_3@newsprd01... > Isolate the layer > Select everything > Open properties (CTRL+1) > Change the Height value to your new text size > > HTH > Russell > >
Hi Laurie, Actually, in the properties window, you can select what type of object you want to edit out of all the selected objects. There is a pull down list at the top that will let you select any of the object types selected. Brian "Laurie Comerford" wrote in message news:412ba8cb$1_3@newsprd01... > Hi, > > This will only work if all the objects on the layer are text. > > The Land Desktop tools I would use are > [Utilities][Selection Set] SS from the command line to select all the text > on the layer. > [Utilities][Replace Blocks/Text] > > -- > > > Laurie Comerford > CADApps > www.cadapps.com.au > > "Russell Dieges" wrote in message > news:412b5e41$1_3@newsprd01... > > Isolate the layer > > Select everything > > Open properties (CTRL+1) > > Change the Height value to your new text size > > > > HTH > > Russell > > > > > >
explorenb wrote: > Is it possible to change text size on a specfic layer. I have a layer that text is too small to read and wish to change all the text using one command, ie. present text size 10 m, change to 20 m height. how about scaletext? jon
