We recently switched to Land Desktop Companion 2009 from 2007 & noticed that the centerline symbol comes out as a question mark in TEXT objects…but when we convert it to MTEXT, it displays correctly. The TEXT object appears to be using the same fonts as when it’s converted to MTEXT. Also, when we open the same file up in LD 2007, it appears correctly even if it’s a TEXT object…even on different workstations. Is this simply how 2009 handles these symbols? Or is it a bug or just a setting that needs to be adjusted?
Thanks in advanced for the feedback!
