• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Land Desktop
    New Member
    Can you install Autocad Land Desktop on a single server?
    271 Views, 2 Replies
    04-02-2012 01:30 PM
    So that users/clients can start the program and work across the LAN? Assuming the licensing is set up for each user, I do not want to actually install land desktop on each users computer. I think it is land desktop 2012 but not 100% certain
    Please use plain text.
    *Expert Elite*
    Re: Can you install Autocad Land Desktop on a single server?
    04-02-2012 07:33 PM in reply to: carmelosawyer
    The last version of Landdesktop was LDT2009, there will be no more.
    As far as I know, each PC requires a separate install, either by direct installing or deployment.
    Jeff_M, also a frequent Swamper
    *Expert Elite*
    TravisNave
    04-09-2012 08:33 AM in reply to: carmelosawyer
    Per the EULA, you cannot install and access Autodesk applications from the server.  This is a license violation.  Some products with special Citrix server licensing are supported.  However, Land Desktop is not one of them.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
