I go to the dwg that contains the CCOs, and then change the Scale tab inside
Projects>Drawing Setup to what I need. After that a Regenall, and I'm done.
Test that out in 2K4 - maybe you really only need one set of CCOs?
And of course this operation would need to be repeated just prior to opening
the respective dwg files for plotting purposes.
But you should remember that CCOs add size to the dwg file, unless you got
through this scenario from the Knowledge Base;
http://tinyurl.com/kyowr
And special care must be taken when transmitting data to those w/o LDT.
I noticed about a month ago that eTransmit has "accommodations" to handle
this with 2K6 - Explode AEC Objects. I don't know how far back those
accommodations extend into earlier releases.
HTH
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
C3D/LDT/CD/SVY-2K6
Intel P4-3.00GHz
XPPro 32bit SP2
1GB RAM
Nvidia GeForce2 Ti 64MB
"Joe Bouza"
wrote in message
news:5104655@discussion.autodesk.com...
Good morning Don.
Is this auto scaling new to 2006? 2004 you have to make 2 sets for two
scales?
How are you doing this?
Joe
"Don Reichle" wrote in message
news:5104409@discussion.autodesk.com...
I've just recently switched from advocating their non-use to advocating
their use.
What lead to the reversal was discovering the use of switching "instantly"
(well, within minutes anyway) from one Scale to another.
I was recently working on an airport Hangar which was going to need 20 Scale
grading plans for the automobile parking area, while the Tarmac and Drainage
Channel would be well-shown in 40 Scale.
Piece o' cake for the CCOs. Only one set was necessary to cover both uses. I
would have spent twice as much time (read $) in attempting the same with
polylines.
My memory still includes how much more size CCOs add to the dwg, but in
conjunction with abilities - No brainer.
Don Reichle
C3D/LDT/CD/SVY-2K6
Intel P4-3.00GHz
XPPro 32bit SP2
1GB RAM
wrote in message news:5104344@discussion.autodesk.com...
I don't dare use the Civil contour items. Last place I worked, about 4
years ag,o one of the other engineers said that as far as he could
determine, the function of contour objects was to corrupt CAD files. They
kept coming up 'not parrallel to UCS' until exploded to poly lines.
Autodesk doesn't seem to want to acknowledge them either as you can't FILTER
for them.
Our CAD staff refuses to use the contour label functions anyway.
As it is, I have so many corrupt files, they refuse to take a CAD file from
me. I think it is the grading & template functions as I am the only one I
know who actually uses them.
