• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Land Desktop
    New Member
    kellyohern
    Autodesk Land Desktop 2007
    769 Views, 3 Replies
    09-07-2011 11:11 AM
    In the course of our work we receive dwg files from other companies and 99% of the time we are able to open them and manipulate data for our use, but occassionally when we open a file and try to manipulate data the message, "Autodesk Land Desktop cannot initialize because this drawing contains objects from a newer version", comes up.  We have the senders try to save it in older versions and resend it but we get the same message.  Is there any way of fixing this situation?
    Please use plain text.
    Re: Autodesk Land Desktop 2007
    09-07-2011 01:43 PM in reply to: kellyohern
    Check to see if you have the object enabler program loaded for your version of AutoCAD.  If you don't you can download it from AutoDESK.
    New Member
    03-29-2012 07:59 PM in reply to: kellyohern
       i need to tray Autodesk Land Desktop 2007
    Active Contributor
    lhampton
    04-03-2012 12:48 PM in reply to: kellyohern
    Download the autodesk "Dwg True View 2012" (here) its a free .dwg viewer that will open and convert most .dwg's to whatever format you want....
    Intel i7 2600 /z68 Gigabyte
    8gigs DDR3 1800
    Intel 320 Series SSD
    Quadro 600 (1gig)
    C3D 2013 / LDT 2009 / Win7 x64
