AutoCAD Land Desktop (Read Only)
AutoCAD 2007: Exporting Points to a Text File creates unnecessary spaces
2 REPLIES 2
650 Views, 2 Replies
When using AutoCAD 2007, when I export points using the Comma Delimited (PNEZD format), the text file that is created puts spaces after the commas that separate the PNEZD information. It never did this in previous versions. This is causing problems when I then try to conver the TEXT file into a JOB file.
If anyone has run into this problem, what is the solution?
2 REPLIES 2
Have you installed the Service Packs? SP2a was released earlier today. Here
are the items fixed in SP1...note the third item under points.
Autodesk Land Desktop 2007 Resolved Issues
Grading
a.. Editing slope tags no longer causes grading lines to be removed.
Labels
a.. Attempting to grip edit a curve whose label exists on a locked layer
no longer causes the program to terminate unexpectedly.
Parcels
a.. An issue with breaking parcel lines using the Break Lines\Curves
command has been resolved.
Points
a.. The program no longer terminates unexpectedly when listing multiple
point groups using the List Points dialog box.
b.. When importing points from a .csv file, the Format Manager (Points >
Import\Export points > Format Manager) now handles information in
user-defined fields as expected.
c.. An issue with exporting points to a delimited file has been resolved.
The program no longer adds a space after every delimiter in the point file.
d.. Creating points by selecting grid coordinates on a surface no longer
creates the points in the opposite quadrant.
e.. An issue with the Format Manager Point File Format dialog box
displaying invalid characters has been resolved.
Projects
wrote in message news:5423696@discussion.autodesk.com...
into a JOB file.
Very good, thank you for your help.
